softtop not working
I recently bought a '91 500SL. The soft top worked but yesterday would not good down. The storage lid opened and that is as far as the process went. Someone told me I could unplug the computer and replug it and that might fix the problem. However, I don't know where to find it although someone told me it was under the passenger seat under the carpet? Does anyone have any knowledge of this problem and fix? Thanks, I am a new user.
check the hydraulic oil level. maybe it's low. it's inside the trunk on the middle area together with the motor and pump.
quantity when full is 0.42 liter.
use only ZH-M. the same oil use in level control system, hydropneumatic suspension, ASD, and 4matic.
Follow-up on resetting the Top Computer... Finally got it into the shop. Resetting (rebooting) the computer was not done by either removing the battery form the circuit nor
uplugging the computer (tried both unsuccesfully). The shop hooked a test set to the computer and reset it.
$45 later everything works fine.
LIKE SLEEPWARKER SAID MIGHT BE LOW ON FLUID..IF NOT ARE YOUR WINDOWS WORKING???IF NOT TOP NOT GOING TO WORK CHECK FUSES IN TRUCK AREA...FOR WINDOWS ,,ALSO THEY HAVE LOTS OF LIMIT SWITCHES YOU WOULDNT BELIVE ONE MIGHT BE OUT OF ADJUSTMENT...
MB-500SL
02-27-2012 12:07 PM
safecents
02-27-2007 04:14 PM
MB-500SL
05-18-2004 06:16 AM
