sl500 windshield washer reservoir
Old May 29, 2012 | 05:07 AM
turbozeke418's Avatar
Default sl500 windshield washer reservoir
I just bought my first SL500 last week and I love it! It is amazing. The only issue I need to fix is the windershield washer fluid. It doesn't work. When the "wash" feature is pushed in I can't even hear the motor run to squirt out the fluid. I'm good with diagnosing on older 123 chassis cars, but this is a little more technical and I was hoping someone has a "usual culprit" scenerio for this to make it easier for me.
Old May 29, 2012 | 10:43 AM
chassis221's Avatar
Usually the pump itself..goes bad..but you could make sure the fuse is good. Or if you can check for voltage at the pump connector when operating the washers.
Old May 31, 2012 | 10:50 AM
96SL500's Avatar
From: Manatee County, Florida- Sarasota mailing address
If your R129 still has the headlight washer, you can switch the pump to the windshield washer position. There are 2 pumps but are both the same (at least on my 96). There is a rubber grommet at the bottom that keeps the fluid in so I found the easiest way is to remove the reservoir, empty the contents (save or not) and switch the pumps. When you order a new one or 2 order new and extra grommets Perf.products is reasonable.
Old Jun 7, 2012 | 11:53 PM
I checked the fuse and connected a test light to the connector that goes to the washer pump motor. It works. the pump motor does not. When I took it out I noticed to things. What is the orange connector that isn't connected to anything and the blue arrow is two wires connected together that come from the water hose itself. If either of these aren't apart of the solution then I would think that the motor itself is bad?
Old Jun 16, 2012 | 01:05 PM
new motor $20 issues resolved
djfelip
Jan 7, 2008 09:04 PM
bordaval
Apr 1, 2005 02:17 PM
honeybee
Mar 14, 2004 07:10 PM
Paul
Jan 20, 2004 03:50 AM
honeybee
Jan 18, 2004 02:16 PM
