SL500 Hardtop Hydraulics
I have a 98 SL500 with a hardtop that will not pull down all of the way on the passenger rear. If I hold the top control switch forward, it will pull the top closer to the body (just perfect). When the switch is released, it will come up about 3/8". I have tried to adjust the rear latch in the body and it makes no difference. Could there be air trapped in the hydraulic cylinder? Might it be an alignment problem? I hate getting the additional wind noise and some water leakage in a driving rain. Soft top works fine. Any suggestions would be greatly appreciated. Thanks. CJE
it is normal to go back a little.
the hydraulic seems to have it's job completely.
alignment problem is most likely. just adjust it down a little.
the sealing still looks fine?
lucky you if you take one more peek here before doing it because i am send ing the work procedure.
[IMG]local://upfiles/1/575DD15AE59C454B8FFD8152BD90E766.jpg[/IMG]
[IMG]local://upfiles/1/C32257AA11D341CF9AB13BFA7EF69231.jpg[/IMG]
[IMG]local://upfiles/1/6DF4355A5FB444AB84332853C2C68473.jpg[/IMG]
[IMG]local://upfiles/1/6E4D1377FBD14625867ACCB478A31262.jpg[/IMG]
MB-500SL
Feb 27, 2012 12:07 PM
MB-500SL
May 18, 2004 06:16 AM
