sl500
Old Feb 21, 2010 | 06:38 PM
dvskw's Avatar
Default sl500
The battery went dead after several months of driving the car. Now after charging the battery, the top goes up and stop when it gets in the up right position. The light on the switch starts blinking. Any answers
Old Feb 21, 2010 | 07:57 PM
brookings's Avatar
did you disconnect the ground before charging? what year is it?
Old Feb 22, 2010 | 06:45 AM
mbz connexion's Avatar
If it were mine I'd try a few things.
First I'd manually close and lock the top.
Then I'd hold the close button in the close position for 20 seconds.
Then I'd pull the switch to the open position until the top is fully opened and hold the switch in the open position for 20 seconds. What happens when you open and close the top now?
Old Feb 22, 2010 | 09:07 PM
dvskw's Avatar
Default top want go up
It is a sl500 1999. Charge the battery but did not disconnect the battery. I will try the other things on Wednesday. Thanks
Old Feb 25, 2010 | 04:59 AM
brookings's Avatar
the earlier model sl top controllers had a self diagnostic feature through the soft top switch, but changed I think in 96. charging without disconnecting the battery can mess up your modules including the top controller. where your problem could be a microswitch/sensor I suggest having a dealer diagnose it. hopefully it's a sensor and you didn't smoke the controller.
Old Feb 27, 2010 | 02:23 AM
brookings's Avatar
or put the top completely up or down, with your doors closed, role up your windows and continue to hold down on both of window switches at the same time in the up position for 6 seconds. who knows?
Old Jan 18, 2011 | 12:59 PM
glovercpa's Avatar
Default how to manually operate soft top?
My 97 SL stored, battery dead, charged, now no windows, no top. How can i operate soft top manually?
other ideas?
Old Jan 18, 2011 | 01:05 PM
glovercpa's Avatar
how to manually open/close top? 97 500sl
n9wjv
Aug 1, 2007 11:20 PM
rx71
Apr 14, 2004 05:43 PM
becky
Jan 12, 2004 11:35 AM
hot4SL
Jan 7, 2004 09:45 AM
