SL SPEEDOMETER SIGNAL
Hi, I had an issue with my top not working and thanks to help from Bobterry I was able to diagnose. I found that once i clear the codes my top works again. But once i drive it when i stop i have to erase one code before it will work. One code is 23 which is roll bar module, this code stays on and wont erase but i can still use the top. The other code which will go away is 28 which says no speedometer signal. When i erase this one the top works again but then the code comes back and blocks the top. I was wondering if anyone knows how to check this problem out or where to look to figure out why it says i have no speedometer signal. Thanks in advance for the help. Danny
