SL 600 Electrical problem??
Old Jun 23, 2007 | 09:03 PM
gwbrehm's Avatar
Default SL 600 Electrical problem??
I was hoping someone out there can help me out. I have a 1994 SL600 with 64000 miles. Today I was driving on the interstate without warning the tach quit working, the car bucked a little and then becamevery sluggish. The ASR light and the check engine light came on andfortunatelyI was able to make it back home. I'm thinking it is probably a wiring harness problem , but, not really sure. Anyone have any ideas on a fix??? Thanks
Old Jun 23, 2007 | 09:30 PM
paddlemarv's Avatar
Default RE: SL 600 Electrical problem??
Check out this hyperlink. It refers to the ASR, which I believe should give you some sort of knowledge with your problem.
http://pages.prodigy.net/jforgione/MB_asr.html
Old Jul 1, 2007 | 12:10 PM
gwbrehm's Avatar
Thanks, I'm trying to check the codes. I just wasn't sure if it was all related to the tachometer failure or if there was a wiring harness issue
Old Jul 1, 2007 | 01:13 PM
NAZ's Avatar
NAZ
THE ONLY WAY YOU LL BE ABLE TO TELL IS TO PLUG IT ON DIAG TOOL, POSSIBLE CAUSE THROTTLE ACTUATOR OR SPEED SENSOR,I DONT THINK YOU HAVE ANY WIRING HARNESS FALUT.
Old Jul 11, 2007 | 06:24 AM
gwbrehm's Avatar
Thanks for the info, I tried to pull the fault codes the old fashioned way with three wiresand a lightbut it didn't seem to work too well. I'm going to get a scanner and try again.
Old Jul 11, 2007 | 10:52 AM
bobterry99's Avatar
I suggest checking the fuses that plug-in to the top of the Base module (picture).
[IMG]local://upfiles/4629/9CD0E962E8064B2792C2B105874686AA.jpg[/IMG]
Old Jul 11, 2007 | 03:21 PM
gwbrehm's Avatar
Thanks for the response and the tip. I cleaned all of the regular fuses, didn't know about these. The car hasn't been driven much over the past few years. I'll let you know, thanks again, George
stevemaman
Jun 21, 2009 12:17 PM
4XXXX
Sep 1, 2008 01:52 AM
cspears1
Sep 23, 2007 02:13 PM
byttcool99
Sep 13, 2003 05:34 AM
