removing gear knob 1989 300SL
RE: removing gear **** 1989 300SL
The **** itself doesn't come off . . . the entire shifter does. There's a locknut at the bottom of the shaft, after you loosen that the entire shaft spins counterclockwise to loosen. Of course, you may have to remove some trim pieces in order to get at the locknut.
This answer assumes yours is an automatic, not a manual.
simie
01-04-2008 12:07 PM
