Radio Antennae 1997 SL320
Old Jul 18, 2008 | 10:34 AM
Gene Moses's Avatar
Default Radio Antennae 1997 SL320
Our radio antennae has quit going up or down. Is there a fuse, a quick fix or it it motor time? The radio lights up, the mast is not bent. Thank you.
Old Jul 26, 2008 | 02:10 PM
CaseyAlbert's Avatar
Default RE: Radio Antennae 1997 SL320
Hi Gene;
I just recently picked up a 98 sl500 that had a stuck antenna mast. Do you hear the antenna motor making sounds that it is trying to raise or lower the mast when you turn the key on/off? If yes, your antenna mast may have separated from the nylon drive belt. If you have the inclination to remove the motor from the trunk, then you most certainly can open the unit and see what might be wrong. These units are really quite simple. The problem would be finding the individual parts for them. Good luck.
Old Jul 26, 2008 | 04:44 PM
Gene Moses's Avatar
Thank you. I can hear the motor and suspect your diagnonis is correct. I got one similar reply suggesting the same or a slightly bent mast. It will be a few weeks before I tear into this but I appreciate your response.
Regards,
steveh692
Feb 5, 2010 03:10 AM
steveh692
Jan 28, 2010 04:03 AM
Gene Moses
Aug 17, 2008 11:29 PM
Gene Moses
Jul 18, 2008 10:33 AM
joelynde
May 29, 2007 11:14 PM
