Oil Changes
Old May 9, 2018 | 02:48 PM
seaswirl77's Avatar
Default Oil Changes
I have a 2009 SL550 that I drive approximately 3000 Miles a year. Mercedes say you should change your oil every year. All my oil changes are with Synthetic oil. I don't think it is necessary to changer the oil every year. How do others feel and is there a way of getting rid of the oil change due message?
T
Old May 9, 2018 | 05:49 PM
PelicanParts.com's Avatar
Hello - with new advances for oils, especially synthetic oils; it's recommended that you change your oil every 6-9k miles depending on driving. If you have a scan tool for your Mercedes, you can likely turn off the oil change alert - there isn't a way to do it from any settings within the car. If you're interested in the scan tool, take a look at the link below. It is a simple and great tool to have in general. Please let us know if you have any other questions!
Schwaben Scan Tool
Old May 9, 2018 | 11:55 PM
brookings's Avatar
I like to change oil at about 6,000 using synthetic regardless of time oil sets in the engine as long as you do run the car once in awhile, 3k a year is ok. so every 2 years for you.
Old May 10, 2018 | 11:02 AM
seaswirl77's Avatar
Schwaben Scan Tool
Thanks for the info
Old May 10, 2018 | 03:08 PM
Originally Posted by seaswirl77
Thanks for the info
No problem at all, glad to help!
Old May 15, 2018 | 04:57 PM
DoctorBenz's Avatar
I just got a much needed oil changed this past weekend!
Old Jun 9, 2018 | 12:20 AM
brookings's Avatar
should change abc fluid from 30 to 40 k too. it's fairly easy, need to be clean
lineman84
Jan 22, 2009 09:26 AM
DIAMONDWHITE550
Oct 24, 2008 07:20 AM
GOMES
Mar 12, 2006 07:42 PM
Yai 2010
Jul 5, 2005 12:23 PM
Buck
Mar 5, 2004 01:24 AM
