Lifter noise at start up
I recently have noticed after a couple of days without starting my SL that when it first cranks I'm getting a loud metallic tapping sound. It goes away after a couple of minutes and runs fine from then on.It reminds me of an older Chevy I used to have, I replaced the tapppets and solved the problem. I am not familiar with this engine and was wondering if some one else has had this problem or is it common for these to leak down with 124K miles on the engine.
Thanks for any advice,
RE: Lifter noise at start up
not to bad ,but if you are handy you might be able to do it yourself but you must take off the valve cover and loosen the camshaft bridge that holds down the cam. here is a pic of the oil crossover tubes. the caps on the ends pop off then they dont lubricate correctly.
[IMG]local://upfiles/20215/64D929A1FEF54125A35ABB954590A462.jpg[/IMG]
