fuel treatment
Old Apr 27, 2017 | 07:17 AM
ab4jy's Avatar
Default fuel treatment
After reading a number of nightmare stories regarding hard to start, sputtering etc, and one recommended cure was injector cleaner for older and infrequently driven cars... mine is a 2003 sl500, i drive only around 2000 miles per year and only about 50 miles every 2 weeks in winter it has 37000 actual miles.. so is it a good practice to use a fuel treatment for keeping injectors cleaned for owner/drivers such as me..
if so is there a recommended product you have had experience with that is safe..
thanks
glen
Old Apr 27, 2017 | 01:20 PM
PelicanParts.com's Avatar
Hi Glen - I think that as long as the car gets started every few days and let it run for a few moments, a treatment isn't necessary. If you're storing the car for quite some time, you may want to use an additive to make sure the gas doesn't 'gunk' up, but otherwise it isn't necessary. Just my 2 cents, other members should chime in with their opinions. Hope this helps a bit!
-Dmitry
Old Apr 28, 2017 | 01:25 AM
brookings's Avatar
SeaFoam. do a search
Old Apr 29, 2017 | 06:33 AM
ab4jy's Avatar
Thanks guys for the input, sort of how i figured... will read up on the seafoam, (ive used it for marine and small engines) and maybe drive the machine more, that will be fun to...
thanks again
glen
carid
Feb 28, 2016 08:04 PM
Atticus1
Jan 11, 2016 08:16 PM
hrosmus
Jul 11, 2015 09:11 AM
jdorencc
Nov 18, 2006 05:27 PM
kazacs
Sep 22, 2005 05:42 PM
