engine and cabin filter replacement 01 SL500
Im looking to replace the engine and cabin filter does anyone have full instructions with pic if possible. Dealer wants over $500 to replace i see the parts online for under $100 cant take long or be hard to do i have changed my Toyota and STR8 many times in less than 10 min.
cabin filter is under the passenger side dash. pull down the panel and youll see the filter housing....has slide release to release the cover.
the engine filter is on top of the engine. just pulll off the engine cover and flip it over and youll need torx to remove the filters.
The cabin/pollen filter I've been changing in my '99 is in the engine bay, inside a 'box' at the rear of the bay near the center of the firewall, right above the blower motor. You undo 2 or 3 spring clips to open the lid of the box, then you'll see the existing filter. This is what it looks like...
http://www.autohausaz.com/search/pro.../Pollen Filter
If there's another filter inside the car, I'd like to have a part # for it.
Bob
I have tried pulling down the panel on the passenger side but nit doesnt seem to move i even took out the two screws. I will try again and keep u all posted. I will even take pictures if it works.
Thanks for all the help.
