DASH LITE OUT
does anyone know how to pull out the dash on a 1998 sl5oo. i need to replace one maybe two lite bulbs in the dash and if i can get behind the clear plastic covering speedo and everything else ill clean the glass {plastic} all help will be appreciated mike
On my '94, all you need to do is to get behind the dash and just push it out. It isheld by 4 clips. Or you can make up a little tool out of a hanger. Bend one end about 1/4" and about 8" long. Bend the other end about 3' as a handle. Slip the small end in, and then turn it. Pull out gently around the dash
