cruize control for 82 380sl
Old Aug 7, 2006 | 10:04 PM
Sandi's Avatar
Default cruize control for 82 380sl
The cruize control has digressed from only working at speeds above 60 mph to working intermittently to not working at all. Any ideas where to begin my surch to repair??
Old Aug 8, 2006 | 11:35 AM
SouthernSon's Avatar
Default RE: cruize control for 82 380sl
My '81 did the same thing. I called a company on the west coast and they said I would need to send the actuator (on the engine) and the controller (under the dash) so they could work on both together. I only sent the actuator since it was the easiest to get to. After no reply for several weeks, I called and they stated that they really needed both to 'match' the two. I told them just to send the actuator back and I would do it later. I received the unit back with a bill of $69 for repair. That is better than the original quote of around $250 to 'match' the two. It seems that they simply cleaned and lubed the actuator. After installing the piece, my cruise control worked perfectly. Don't let them rip you off, send only the actuator (from the engine bay). If that doesn't work, then send the unit from under the dash.
Old Sep 8, 2007 | 08:08 AM
disbo's Avatar
Hi, I havea 300 SD with non working cruise control but dont know where to start. You mentioned the actuator but Im not sure which part this is. Could you post a picture? Also, where is the other one under the dash?
The Haynes bookI have doesnt mention anything on how to troubleshoot Cruise control issues so any help is great.
Cheers Chris
BullOnWallSt
Oct 20, 2008 03:57 PM
Basafa
Oct 28, 2006 03:48 PM
rosenlou
Jul 29, 2005 03:08 PM
Tim380
Jan 15, 2004 01:23 AM
11margie
Jan 9, 2004 04:13 AM
