Central Locking Problem
ORIGINAL: Silver_Bullet
Recently bought a SL 500 2005, my door canot open with the remote.. i dont whats the problem even from the interior its not opening..
I know it's an old post but I've got the same problem.
I started having problems with central locking, boot soft closing and lumbar control. I replaced fuse 71 but it blew again within a few seconds.
So I ended up having the PSE pump replaced at my local garage. When the cables were removed though they weren't marked up and a digital photo was taken instead for reference.
I'm just wondering if one or more of the cables have got mixed up though when replacing. They all seem to be back in there 'natural' position but I've had mixed results.
The driver side door works perfectly now and locks and unlocks as it should. But the boot and passenger door and lumbar support still don't work.
A strange thing is when I attempt to open up the boot it locks the passenger door.
Has anybody got a diagram showing where the cables go? Failing that does anybody have a suggestion on what would be the best method to systematically check each cable.
Lastly, I've also seen on some posts that the PSE pump needs to be coded. Can anyone confirm this. I did actually take it back to the main dealer to test on the star machine but no mention was made about coding.
Thanks for any help.
If you have a volt/ohm meter you can check the cables for shorts by disconnecting the battery and then use the ohm meter setting to see if you get a short reading between the cable and the ground (frame). The ohms should be near infinity unless there is a short then resistance will fall to near zero. The meters are an inexpensive ( around $20-30) tool everyone should have in their toolbox.
