ABS / BAS & ESP WARNING LAMPS ON
Hi all,
I wondered if anyone here has an idea of what is going on with my dash unit...
I did a little work under the rear seat on the weekend, I had to disconnect the roof control unit so I removed the appropriate fuses to remove the power to this unit first.
However now I have the above lights on, on the dash, right from ignition start. I have tried the steering sensor reset (turn left & right) but no change, I tried removing the battery just incase but no change.
Running out of ideas here...
Anyone???[/align]
Anyone???[/align]
I would check the fuses mounted in the top of the base module because it supplies power to the ESP module. If those are okay, then I would read diagnostic codes. Since this car is newer than '95 a Mercedes-specific code scanner is required. A Mercedes repair shop can do it, or you can get a Carsoft compatible scanner on eBay for about $100. I have two of these, and while they don't do everything they are advertised to do, they work great.
LABoy
01-30-2008 01:16 AM
