98 sl500 headlight washers
Old May 11, 2015 | 11:38 PM
  #11
brookings's Avatar
on my 90sl the #1 fuse powers the anti-theft alarm, the right standing lamp, the right tail lamp, side marker lamp, exterior lamp failure monitoring module, exterior lamp switch, instrument cluster, license plate lamps, and headlight washer. have you tried unplugging the wiper motors one at a time, not the pump, and see what happens? the wiper motor maybe the problem. you'll need to pull headlight to access
Old May 13, 2015 | 03:38 PM
  #12
96SL500's Avatar
From: Manatee County, Florida- Sarasota mailing address
So far I've tried it with the pump unpluged and the #1 fuse pulled. I didn't think to check lights but I will. It runs fine and no warning lights are on except the fluid level. I had a 1/2 gallon but my reservoir holds 3x that amount. I've purchased more. Not certain where the headlight wiper motor plugs in. I'm sure it is under the reservoir so I will take that out again. HOWEVER if it works like it is and no other lights are out, I may just go with the fuse out and the pump unplugged until it is cooler (November).
Old Jun 9, 2015 | 12:41 AM
  #13
brookings's Avatar
remove headlights to access wiper motors
bmaxey
Feb 20, 2009 06:16 PM
BOSTON JOE
Nov 27, 2007 10:05 AM
stevec
Jul 28, 2007 04:21 AM
rohitsagar
Aug 12, 2005 02:54 AM
s40guy
Apr 5, 2005 02:44 PM
