95 SL500 needs motor mounts???
Old Jul 16, 2009 | 11:05 PM
Kpassa's Avatar
Default 95 SL500 needs motor mounts???
The dealer told us our 1995 SL500 with less than 53000 miles on it needs motor mounts, they said it's just because of the age of the car they have collapsed. Why would that be? The car was babied, it's not like it was used for rock climbing in the backcountry Is this another part that was just poorly designed like the wiring harness? For a car that was supposedly one of the best designs ever made I would expect its parts to last longer than a Ford Pinto.
Old Jul 17, 2009 | 09:02 PM
aviteck5's Avatar
It is the nature of the car. I have seen some 210 chassis E-Classes with 30,000 miles that need engine mounts because the engine is drooping. I guess the rubber will just deteriorate over time and the mounts will collapse.
Old Jul 17, 2009 | 11:27 PM
Kpassa's Avatar
You're right, I just needed to vent. You expect things like brakes, belts, etc., to fail, that's just normal wear and tear. These expensive little flaws aren't something you expect to find in a $10k car so it's frustrating to find them in one that costs 10x as much.
Old Jul 25, 2009 | 04:25 PM
Kpassa's Avatar
Originally Posted by ForcedInduction
Its normal maintenance. 50k miles is pretty good for a $30 part.
Not if it costs $900 to replace it.
Old Jul 25, 2009 | 09:14 PM
chassis221's Avatar
i can see 4 hours labor maybe at most. the motor needs to be raised and maybe a drop of the steering drag link maybe necessary. what was the reason for the motor mount replacement?
Old Jul 27, 2009 | 06:23 PM
Kpassa's Avatar
I haven't had them replaced yet. The dealer noted it on a routine service check and said it would cost $900 to repair.
Old Aug 25, 2009 | 06:47 AM
rgrayoh's Avatar
I have a 1994 SL and I have replaced 2 sets of motor mounts (first time at 45,000 miles and the next set at about 127,000 miles). At 131,000 I was told by my dealership that my motor mounts have colapsed and I need to replace them again. I don't know why they are not manufactured better.
Kpassa
Oct 8, 2009 09:32 PM
C280 Fan
Nov 20, 2006 09:27 PM
drblank
Oct 11, 2006 02:23 PM
rmt6668
May 14, 2006 09:35 AM
mr_man12
Sep 21, 2005 05:35 PM
