Motor Mounts Broken?
Old May 12, 2006 | 10:41 AM
rmt6668's Avatar
Default Motor Mounts Broken?
My authorised MB Motor shop in Aug replace only 1 mount because when reversing (gear on Reverse), the car vibrates badly. But he check when on Drive, it do not vibrate.
So only 1 mount was replaced in Aug'05.
Yesterday the other motor shop who replace the water tank & Radiator, spotted both mounts broken.
The question is either he presume 2 need to replace at same time without realising the other shop had replaced last yr or previous Shop had done something to stop the vibrating?
Currently on Drive i dont notice much vibration even on stationary. I suspect its the right mount which was replaced, am i right?
Some 1 mention if not replace it may cause stress upon other parts of engine, what are those possibilities??
Kind Regards
Old May 13, 2006 | 07:03 PM
vytamenc's Avatar
Default RE: Motor Mounts Broken?
was your car under warrenty when this mount was replaced? is so then they only replaced the mount that was bad thats all warrenty will pay to replace is the failed part........... now will it cause stress on the other mount doubt it
Old May 13, 2006 | 10:54 PM
rmt6668's Avatar
The car is 11 yrs old, no warranty.
Correction, the L/H mount is the one seen rise& lower during the Reverse & drive gear (with brake on). Whereas the R/H mount hardly any movement, meaning its collapse, correct?
Its mention oil contamination, can damage the mount? How is that?
Also I notice in my radiator/water pump leak previously the colour of the coolant by the previous authorised MB service shop is green colour. Some post mention that MB engine dont like green coolant. Now with the new Raidator/water pump in place, I notice coolant in reservouir is not green, look like lemon colour I guess.
Kind Regards
Old May 13, 2006 | 11:24 PM
sleepwalker's Avatar
it can't be because it is oil filled.
Old May 14, 2006 | 09:31 AM
rmt6668's Avatar
What cannot be? The oil or rubber mount?
Old May 14, 2006 | 09:35 AM
rubber mount got oil inside.
it is the oil which absorbs vibration.
if oil contamination can damage it... they shouldn't design it with oil inside on the first place.
AMGMercedes
Jul 25, 2007 07:33 PM
brudd
Mar 4, 2007 07:10 PM
C280 Fan
Nov 20, 2006 09:27 PM
drblank
Oct 11, 2006 02:23 PM
mr_man12
Sep 21, 2005 05:35 PM
