560sl Seats in a 450sl
RE: 560sl Seats in a 450sl
After some trial and error, I can now answer my own question.
Yes, 560sl seats will fit into a 450sl with only a simple modification--no drilling or welding. The frame rails will need to be used from a 450 since they bolt differently into the floor tub. However all this amounts to is sliding the older rails onto the newer seat. Also, the seat belt uses a different buckle so either the entire 560 belt hardware needs to be swapped or the buckle from the 450 needs to be bolted onto the inside of the seat frame.
sdunham
12-27-2006 07:23 PM
YuCrew
04-14-2004 02:20 AM
