30K mile maintenance
Old Sep 5, 2011 | 02:55 PM
87_560SL's Avatar
Default 30K mile maintenance
I'm brand new to this site and also considering buying a very low mileage '87 560SL and it has yet to have the 30K mile maintenance...it is still not there! What is to be done at 30K? What else should I expect to do immediately with this 24 y.o. ride? Thanks!
Old Sep 7, 2011 | 10:01 AM
87_560SL's Avatar
Well then, is there anywhere online where I can view the maintenance schedule for a 560SL?
Old Sep 7, 2011 | 02:25 PM
gilgorm's Avatar
I would ask the seller for his history and then judge what needs to be done. The maintenance schedule went out the window years ago due to the excess years as opposed to mileage. With low miles you can expect to pay top dollar (depending on condition) and should expect to replace the fluids and belts when you get the vehicle. If the seller has history then judge if everything or nothing needs to be replaced. The seller should also have an operating manual and a maintenance schedule.
GL
Old Sep 7, 2011 | 03:05 PM
87_560SL's Avatar
Thanks for the response gilgorm.
I realize that age does matter as opposed to miles, and I understand (someone said here) that the 30K mile maintenance is a $1000 checklist. I was just curious as to what is on the list (I don't have a maintenance schedule book yet).
Old Sep 7, 2011 | 03:16 PM
87_560SL's Avatar
Does this list look familiar for proper preventative maintenance, or is some of it unnecessary for a 25K miles car.
- Replace timing chain, tensioner, and upper rails
- Replace driveshaft bearing with housing
- Replace flex discs (front and rear)
- Replace throttle housing with air valve
- valve cover gaskets
- copper seals
- plugs, wires, cap and rotor
- fuel pump relay
- belts
- ignition coil
- air filter
- oil change
- steering shock
- air pump filter
- air duct boat flange
the cooling system and the A/C is not addressed on this list
Old Sep 8, 2011 | 07:56 AM
87_560SL's Avatar
What electronic components have a high failure rate...ie: what will deteriorate with age regardless of mileage and should be addressed? I'm wondering about the fuel system controls maybe...
Old Sep 8, 2011 | 09:20 AM
SunGuy62's Avatar
Have you had a qualified independent Mercedes Tech do a Pre-Purchase Inspection of this car? Typically, this service runs $100 - $200, takes an hour to 1 1/2 hours to complete, is the best possible investment you can make before you decide to buy, and will answer all your questions including should you even buy it in the first place.
Old Sep 8, 2011 | 09:48 AM
SunGuy62's Avatar
You can also look at these two sites for information on the 560SL's...
ourSL, 560SL BOOTCAMP
ourSL, Mercedes-Benz 560SL evaluation photographic essay
Old Sep 8, 2011 | 01:02 PM
  #9
87_560SL's Avatar
Thanks SunGuy. That is very helpful!
Old Sep 8, 2011 | 02:13 PM
  #10
SunGuy62's Avatar
Good...focusing on what this or any other car may need before you buy it, IMO, is the only way to go. It puts you in a better bargaining position knowing what's going one with the car, and you'll minimize the after-purchase maintenance $urprise$.
Good hunting-
87_560SL
Sep 7, 2011 06:38 AM
iforsyth
Dec 3, 2006 04:24 AM
hsieh
Aug 22, 2005 08:41 PM
hsieh
Aug 22, 2005 08:37 PM
DOCJAY
Mar 24, 2004 11:23 AM
