1995 sl600 check engine light
hello everyone, new to this forum because i've recently bought a 1995 sl600. Got a great deal on it and is in excellent shape, 91,000 miles. Only thing is, that it has check engine light on and am told cars before 96' don't have obd2 ports. my question is, is how do i check the code without it or am i stuck taking it into the dealer? Thank you in advance, ive searched the internet and am unable to come up w/ some sort of answer. Car seems to be running great
check for vacuum leaks. make sure vacuum pump is working. It's not an exact science, even with codes it's a guess as to what in the secondary air injection system could be the problem. it could be an oxygen sensor, airflow sensor, bad vacuum hose, pump etc. generally it won't cause you to break down someplace. I would check hoses first, then pull a line off the vacuum pump to see if it works, then change 02 sensor.
Since it's pre OBD2, it makes it difficult to run codes. You'll have to grab a manual with the codes listed and count the number of blinks that the module makes - this in turn matches a code in the book. I would suggest having the dealer take care of the codes if you're not too familiar with the process.
Kikoap
Jul 30, 2012 02:50 PM
Kikoap
Mar 27, 2012 10:37 PM
krisgt2@hotmail.com
Sep 28, 2007 01:41 AM
