Transmission Pressure sensor
Old Jul 10, 2006 | 01:33 AM
mr2weenie's Avatar
Default Transmission Pressure sensor
Hi guys!-
I have a 1992 Mercedes 400SE. There is a leak somewhere at the rear of my transmission. After inspecting it, I discoverd that it is not coming from the outputshaft seal and is not the pan gasket. It appears to be coming from a sensor on the right rear of the transmission. This sensor has a 19mm banjo Bolt with a valve at the tip, that runs all the way through the electrical portion of the sensor, and seals to the trans with an aluminium washer, and the banjo bolt has 3 o-rings on it. I cant tell how this sensor works, or if to get it to stop leaking I need to replace the banjo bolt and 0-rings or the elctrical portion.
For example and oil pressure sensor when it leaks you replace the whole thing, but because this is a two piece deal with a sealing washer, I can t tell if the electrical portion even has oil running through it. Anyone else been through this or know what I am refering to?
Old Jul 10, 2006 | 04:21 AM
sleepwalker's Avatar
Default RE: Transmission Pressure sensor
kickdown solenoid valve.
just replace the O-rings. coat with a little grease before installing so it won't get scratched.
newport5
Sep 12, 2008 12:19 PM
hughits
Jun 24, 2008 02:19 PM
michael27
Feb 25, 2008 12:06 AM
empi123
Jun 10, 2007 11:31 AM
techteam
Sep 27, 2005 12:43 AM
