S500 Vibration
Old Jul 28, 2006 | 09:27 PM
lmcclin2's Avatar
Default S500 Vibration
I have a 2000 S500. It sometimes vibrates around 40 to 60 mph. The entire car vibrates. The back seat, the passengers seat and a bit throught the steering wheel. I have purchased new wheel and tires and I still have the same problem. It does not occur all the time and I cannot force it to happen. The first time it happened, I thought a wheel was coming off but all lugs were tight. Any ideas? Thanks.
Old Jul 28, 2006 | 09:42 PM
vovpar's Avatar
Default RE: S500 Vibration
did you check alignment??
Old Jul 28, 2006 | 09:53 PM
lmcclin2's Avatar
Not yet. My next stop is to have the four wheel alighment performed by the dealer.
Old Jul 29, 2006 | 03:05 AM
vovpar's Avatar
Depends where u are located, my dealer charges a lot for alignment and wheel balancing. Try using specialized independent shops that do alignment.
Old Jul 29, 2006 | 03:55 AM
sleepwalker's Avatar
check the flexible discs of the propeller.
Old Jul 29, 2006 | 10:28 AM
lmcclin2's Avatar
Thanks you for the suggestion. I am not totally familar with all of the technical terms so is this part of the drive train/rear end system?
Old Jul 29, 2006 | 10:31 AM
you got two.
one that connects it to the transmission and the other one connects it to the rear differential.
check both of them.
there must be no play, tear, or enlarged mounting holes.
Old Jul 29, 2006 | 10:33 AM
ORIGINAL: lmcclin2
some call it:
joint
universal joint
coupling
rubber disk
etc.
Old Jul 29, 2006 | 08:41 PM
  #9
lmcclin2's Avatar
This really helps. I will take it to the dealer and update this forum on the status. Thank you very much. I was afraid that I would get caught up in chasing a symptom, making repairs that are not needed and still having the problem. At least this will help to focus on the most likely problem area.
Old Jul 30, 2006 | 12:38 PM
  #10
97dmsrS420's Avatar
Is there such a thing as the entire drive shaft needing to be replaced? And, under what circumstances would the drive shaft need to be replaced (other than the obviously, as with an accident of some sort)? The U-Joints of these drive shafts are sealed, are they not? I've noticed that they're not sold a lot, at least not for my vehicle. But the flexible disk...well... I never thought that would be a source of drive-line vibration! That is enlightening! And I thank you as well, because I've been having some vibration as well, and like this fella, I kept thinking it was wheels, tires, shocks, tie-rod ends, control arms, bushings, etc. Thanks
