S500 Engine cut off when hot [W140]
Hello,
I have this W140 S500 WDB1400512A197157 engine cut off when hot. So far what I replaced were:
1, Crankshaft sensor
2, Camshaft sensor
3, Fuel pump x2
4, Fuel filter
5,Temp sensor (single connection)
6, Distributor cap x2
7, Distributor rotor x2
8, Electronic throttle valve ( MOST EXPENSIVE )
9, Fuel pump relay
10, HT cables x 10 (including 2 coil cable)
11, Spark plugs x8
What I have NOT replace
1, Coils x 2
2, Ignition control unit
3, ECU
4,MAF sensor
Any solution or did i miss check something ? Any advice ?
Thanks.
2, Camshaft sensor
3, Fuel pump x2
4, Fuel filter
9, Fuel pump relay
11, Spark plugs x8
1, Coils x 2
3, ECU
4,MAF sensor
Thanks.
