S280 key wont turn in the ignition - CAN problem
Old Aug 14, 2008 | 05:29 AM
Auto iQ's Avatar
Default S280 key wont turn in the ignition - CAN problem
can turn the key if you play with the key, star brings up
ETC> one or more messages from N73 EZS not available on can or intermittently not available on can
ESM> P1906 stop lamp switch signal from N73 EZS is not available on CAN, Motor electronics> P1570 start enabled of DAS not sent P1747-062 can fault A1 instrument cluster, P1603 no or incorect message from EZS,
ESP> C1022-020 can communication with engine faulty, fault in can with N72/1s1 esp off switch or S12 parking brake indicator switch, C1140-016 N49 sterring ang. sensor fault in CAN with N80 steering column module
AIRmatic> C1026-002 fault in can with EZS, fault in CAN with N80
car will start but ESP and BAS come on dash. no faults when you put the key in and dont crank the engine with quick test , once you start the engine, faults back
what would you recomend, anyone had similar problem?????? we checked all the wiering, replaced esp button module on center dash with a good one, still the same, compared to other car when can is disconnected from ezs key should always turn... it wont start, but it turns....
EZS faulty.... or any other idea, please advise
Kris
Old Aug 15, 2008 | 02:58 AM
sleepwalker's Avatar
Default RE: S280 key wont turn in the ignition - CAN problem
what year model was that?
Old Aug 15, 2008 | 04:08 AM
Auto iQ's Avatar
year 2000
Myran
Dec 6, 2018 03:17 PM
DonRobbie
Apr 12, 2012 09:46 PM
jannashome
Jun 4, 2010 06:00 PM
paulT
May 3, 2009 09:36 PM
