Purge valve & Transmission fault Founded??
Old Nov 30, 2017 | 08:56 PM
kevlex4's Avatar
Post Purge valve & Transmission fault Founded??
Machanic performed and entire system reset then told me to cross my fingers because additional work is in my future.
How much would a new or rebuilt tranny cost and how many miles will it last do I even need a new/rebuilt transmission?
Or just a tranny tune up kit we are at 109,111 miles.
Transfluid and seal was changed about 100,000 ago is this normal??
Old Dec 1, 2017 | 12:14 PM
PelicanParts.com's Avatar
Hello - what platform is this in regards to?
Old Dec 2, 2017 | 11:53 PM
kevlex4's Avatar
2007 S550 4matic 109,xxx
Old Dec 4, 2017 | 03:45 PM
Thanks - what was the transmission fault that was found? I believe a rebuilt transmission will set you back about $3k USD; this is just a ballpark figure - other members may chime in as well.
Old Dec 7, 2017 | 01:28 PM
kevlex4's Avatar
Yeah thanks I will attempt to find
a respectable Transission shop to do the work or maybe a used transission from another s550? Is that possible
Old Dec 7, 2017 | 04:00 PM
I would do a search for European car junkyards /used part supplier or ones that deal specifically with MB - you can likely find a used one for a good price.
Old Dec 13, 2017 | 08:26 PM
kevlex4's Avatar
I finally gave up an went to a professional shop ammaco transmissions labour is $1,5××× not inculding taxes. The parts must be shipped in its a 1-5 job the hydrolic something and a few other things like gears berrings stuff are the parts as expensive as the labour?
Old Dec 29, 2017 | 07:31 PM
kevlex4's Avatar
Finally my transmission job is completed by Ammaco here is the break down on parts replaced inside this Transmissions guts New Valve body including Programming $2,350 10 bottles of ATF $232.00, 1 filter $43.00 1 new Master assembly kit $1,008.08 1 E Torque Converter $495.00. Labor $1,589.44. Grand total including NYC tax =$6,225.95
Thats the most expensive repair bill I have ever had.
The transmission seems stiff strong and heavy the tech said give it some time to be broken in (feels like a new car. Hopefully this transmission will last another 100k miles. We are at 109k now. Seems like the 722.9 transmission has a 10 year life span.
Old Apr 3, 2021 | 05:15 PM
  #9
kevlex4's Avatar
Default 16k miles later transmission failed again
spoke too soon its 2years later 16k miles and tranny went haywire again merdedesbenz of brooklyn wants ransom and blood money running out of options help
Mbz300sd
Aug 31, 2014 06:46 AM
Newbenz
May 28, 2009 11:06 AM
mhacket
Mar 17, 2007 07:28 PM
1990300SELMAN
Sep 29, 2005 09:13 PM
Jasper
Feb 9, 2004 02:23 PM
