One headlight Dimmer than the other
Old Jun 4, 2013 | 05:27 PM
DACS430's Avatar
Question One headlight Dimmer than the other
I have an '06 S430 4Matic (36,000 miles). I recently had a headlight bulb blow on me. I replaced both bulbs ( H7) with Sylvania SilverStar bulbs. I then noticed that the drivers side light was dimmer than the passenger side. I went back today, and replaced those with standard Sylvania H7 bulbs. When I went to check again, the driver's side is still much dimmer than the other. Please Help... Thanks in Advance.
Old Jun 4, 2013 | 08:38 PM
chassis221's Avatar
probably aimed incorrectly so it looks dimmer
Old Jun 4, 2013 | 09:55 PM
DACS430's Avatar
Chassis221, I've tried turning the bulb several times, with no change. Is there anything else that I am not doing correctly, or need to do?
Old Jun 5, 2013 | 07:10 AM
Elektrische's Avatar
Walk a good distance away from the car and bend down low to the road and look at the lights.
If it still looks dim...
Check the electrical connections with a multimeter, DC Volts. See if the voltage is lower on the side which is dim.
A poor electrical connection or damaged wire will not let as much electricity "through" to the light.
I don't have electrical diagrams for that year, but there can be various electrical connections on cables going to the lights, a relay (electrically operated switch), etc.
JJT BENZ
Oct 23, 2011 05:04 AM
wcmartin75
Jul 13, 2010 04:27 PM
Tinkerinmatt
Apr 25, 2009 05:36 PM
alinux
Dec 23, 2008 09:38 AM
SilverSaloon
Mar 15, 2004 07:51 AM
