My 2000 S500 acceleration problem?
Old Mar 10, 2010 | 01:43 AM
Fobanginvtek's Avatar
Default My 2000 S500 acceleration problem?
I test drove this car my dad just bought ( will be mine soon ), and as i tried to floor it a little, the acceleration stopped completely. I could not gas it no more, but engine was still on. I push it all the way down and all nothings happening it was just idling. so i had to park it, turn it off and then on, and it worked fine again. Is this a problem for anyone???
Old Mar 10, 2010 | 05:27 PM
chassis221's Avatar
could be a gas pedal you need. thats a common symptom.
Old Mar 11, 2010 | 02:57 AM
pardon? No.....I don't think thats it...
Old Mar 11, 2010 | 08:20 PM
MB-TECH-38's Avatar
Foban,
Chassis gave you his opinion and experiance . do you want a list of things it could be . remember the car is not in front of us . we are trying to diagnose over the NET. the pedal has sensors that need to be read by the engine management system , its not just a Pedal
could be air mass meter
colgged exhaust [ cats ]
fuel problem
injector problem
we can only give you possibilities
Old Mar 11, 2010 | 10:07 PM
chassis221's Avatar
Thank you MB Tech!...Ive replaced many for that exact complaint with a throttle potentiometer codes sometimes throws no codes at all ..usually if you really ease into the gas theyll work but push a more than 40% throttle it has no reaction.just kind of idles.
Old Mar 12, 2010 | 02:12 AM
exactly! i tried to floor it a little aggressively, but not too much...and it just idled and refused to accelerate until i had to park and restart. Is this is issue? Should i not do it? or how can i get it fixed....thanks!
Old Mar 13, 2010 | 06:31 PM
NAZ's Avatar
NAZ
replace AIRMASS SENSOR and problem will be solved throttle padel is very very relaiable,very rare come across this,but the fault u gettin sounds verh much of AIRMASS SENSOR...
Old Mar 14, 2010 | 11:05 PM
sweet thanks
Old Mar 16, 2010 | 03:37 AM
  #9
Rockerfella174's Avatar
Its the Mass Air Flow Sensor.. shouldnt be hard.. replace it with a new one.
rockerfella174
brunei darussalam
Old Jun 15, 2015 | 10:13 AM
  #10
hlhunter's Avatar
yes I have the same problem. I have had my car parked now for 3 months
