My 2000 S500 acceleration problem?
I test drove this car my dad just bought ( will be mine soon ), and as i tried to floor it a little, the acceleration stopped completely. I could not gas it no more, but engine was still on. I push it all the way down and all nothings happening it was just idling. so i had to park it, turn it off and then on, and it worked fine again. Is this a problem for anyone???
could be a gas pedal you need. thats a common symptom.
pardon? No.....I don't think thats it...
Foban,
Chassis gave you his opinion and experiance . do you want a list of things it could be . remember the car is not in front of us . we are trying to diagnose over the NET. the pedal has sensors that need to be read by the engine management system , its not just a Pedal could be air mass meter colgged exhaust [ cats ] fuel problem injector problem we can only give you possibilities |
Thank you MB Tech!...Ive replaced many for that exact complaint with a throttle potentiometer codes sometimes throws no codes at all ..usually if you really ease into the gas theyll work but push a more than 40% throttle it has no reaction.just kind of idles.
Originally Posted by chassis221
(Post 133691)
exactly! i tried to floor it a little aggressively, but not too much...and it just idled and refused to accelerate until i had to park and restart. Is this is issue? Should i not do it? or how can i get it fixed....thanks! |
replace AIRMASS SENSOR and problem will be solved throttle padel is very very relaiable,very rare come across this,but the fault u gettin sounds verh much of AIRMASS SENSOR...
sweet thanks
Its the Mass Air Flow Sensor.. shouldnt be hard.. replace it with a new one.
rockerfella174 brunei darussalam |
Originally Posted by Fobanginvtek
(Post 133602)
yes I have the same problem. I have had my car parked now for 3 months |
