Metal key will not open door
are you the first owner? if not ask the previous owner if you can if the tumbler was ever changed, if it is still the original key tumbler is it turning when you insert the key? if yes then the inside rod mechanism may be loose or disabled. In that case you need to open the sidings from the inside and visually view for reassembling the rod located on the left top portion when viewed from the inside of the door. If the tumbler have been changed then there should be another set of keys, just wondering was it working before? if not then the above step might be the most prudent way to go. avoid spending before you find out what is really wrong.
lynns
06-22-2013 08:20 AM
dgrover
09-03-2008 08:47 AM
