inconsistant high idle/SLEEPWALKER PLEASE HELP ME
Old Apr 20, 2006 | 10:32 PM
h2ocolors's Avatar
Default inconsistant high idle/SLEEPWALKER PLEASE HELP ME
Can somebody give me more info? I just got a 1984 380se, w-126. the problem is a intermittent high idle, up to 1700-2000 r.p.m.'s, which can play havoc trying to shift from park to reverse and back. I have gone back thru several posts and have tried to fix the problem by, first, rapping on the Idle control valve, but no change in idle speed. Second, I have taken the overload protection relay out during proper idle speed. r.p.m. drop's but still runs, with a noticable surge on tach and economy gauge, as a visual. I have heard that the overload relay can have bad solder joints, and I can hear it rattle when it's out and I shake it a little. The 10 amp fuse on top is still o.k. though? Thirdly, I had a few vacuum lines that crumbled in my fingers, replaced them but still no change w/ r.p.m.. These things all happen sometimes from start up or maybe not all day during stop n go driving. I do wish to find the problem d.i.y. cause I'm disabled and social security disability checks just don't stretch. Can anone shed some light my way? I forgot to add that when she's at her "High Idle",that if I turn on the a.c. the r.p.m. drop's to almost normal but the "economy gauge" shows that it's up to about 1/4 on the gauge. VIN# CA32a0ea076402
Old Apr 20, 2006 | 11:19 PM
mbz300sdl's Avatar
Default RE: inconsistant high idle
I have never worked on a 380 motor so i cant help much other than say to list ur VIN number and ask sleepwalker for help. He is a mercedes mechanic in china and the best help possible on this forum. But the overload relay went on my 560 and i replaced it and now i have no problems with surging and high rpms like i did b4 i replaced it but if ur on a tight budget well like u said ur on SS so i guess u are i would wait on a response from sleepwalker. Give him time to notice ur thread though.
Old Apr 20, 2006 | 11:35 PM
h2ocolors's Avatar
Thanks my friend! That VIN# is Ca 32a0ea076402 (for Sleepwalkers info), or who ever can help. The part on line is only 60.00 or so but still would like to be a liitle more for sure. where did you say your residents is? I'm a native So.Cal. guy, Talk @ you soon.
Old Apr 20, 2006 | 11:37 PM
h2ocolors's Avatar
So, why did you chose to replace that item? Did you do a test of some kind?
ORIGINAL: h2ocolors
Old Apr 21, 2006 | 12:57 AM
mbz300sdl's Avatar
I knew that they went bad and i would tap on it and it would run correctly sometimes so i figured it was bad plus one had gone bad on the 300sdl so i put two and two together and replaced it. I live in Maryland about 75 miles west of DC.
Old May 7, 2006 | 07:18 AM
sleepwalker's Avatar
i will look into this tomorrow.
Old May 13, 2006 | 06:37 PM
vytamenc's Avatar
Default RE: inconsistant high idle/SLEEPWALKER PLEASE HELP ME
try your idle speed control unit it controld the air slid valve on that car
MARIODRIVE
Nov 23, 2008 05:39 PM
no respect
Mar 26, 2008 04:07 PM
ps2cho
Aug 4, 2007 08:21 PM
fay3131
Sep 6, 2006 12:48 PM
mythreesons
May 24, 2006 07:28 PM
