Ignition not recognizing key
Recently my 2008 E class has been having trouble recognizing the fob. It makes a hum when it reads the key and then I can turn the key and start the car. Sometimes it takes several insets for it to read. Sometimes it just goes on and then signs off before I can turn the key. I don’t think it’s the battery as the doors and trunk open properly and I have two different keys that are two different ages and it does it with both keys. It must be a sensor not reading my key, but I don’t know what part would need to be replaced. I have tried cleaning the sensors on both the key and the outer part of the ignition where you insert the key. Has anyone else had this problem?
