a/c not blowing anything 01 s500
Old Jul 28, 2006 | 07:59 PM
ahmedny's Avatar
Default a/c not blowing anything 01 s500
hello
i have a 2001 s500 with 138K ..for some reason the a/c, heat stopped blowing anything no air or heat what so ever.
i happend a few times a couple of weeks ago when it wasnt blowing anything ,so i turned off the car restarted it and then it started working again .but now nothing.it shows it going on ,on the display ,but doesnt blow anything..any suggestions?..also does anyone have a fuse chart for this car ?..i would appreciate any help.thank you.
my email address is ahmednyny@yahoo.com
Old Jul 28, 2006 | 09:37 PM
vovpar's Avatar
Default RE: a/c not blowing anything 01 s500
Your blower motor may be bad, or you can check your fuses.
Old Jul 28, 2006 | 09:54 PM
ahmedny's Avatar
can you please let me know which fuses they are ?
i dont have a chart of the fuses. also do you think it may be the regulator? thank you for your help
Old Jul 29, 2006 | 05:33 PM
vovpar's Avatar
i dont know which fuses are responsible for the blower, but if you have time, you can go through the fuses under back seat, under the hood, or on the passanger side of the dash.
Old Jul 30, 2006 | 12:52 PM
97dmsrS420's Avatar
Could it also be the climate control unit itself?
Old Jul 30, 2006 | 05:28 PM
vovpar's Avatar
ORIGINAL: 97dmsrS420
it could be, there are many possibilities, to check climate control unit you need to take apart center console, and i dont think you will be able to see if its bad or not just by looking at it. New unit is about 300$, so i would check fuses first and the blower motor itself.
Old Jul 30, 2006 | 08:56 PM
vovpar's Avatar
...also, I think dealer can reset your AC control unit
Old Jul 31, 2006 | 12:11 AM
sleepwalker's Avatar
the blower must be stucked.
try turning it with your finger and see if it's binding.
replace it.
geminichrisw126
Aug 29, 2010 07:45 PM
mgw_300e
May 18, 2008 09:54 AM
donovanneb
Mar 10, 2006 07:12 PM
67fb
Jun 6, 2005 10:48 AM
