a/c blows what ever temp is out side?!?!?
i tried to fill my a/c in my s600, but the line has over 100 psi in it and say the line could blow anytime. it also wont take in any freon. (well only 1lb ) what could the problem be?
evacuate it first and see how much you get. could be overfilled. or there is a clog someplace. usually take about 2lbs depending on if you have rear AC. then 2.3 not exactly sure on that amount but 2.0-2.5 is usually good.
check the evaptemp sensor and also the temp. or pressure sensors on the reciever drier. stil seems like you have a clog. on alot of the newer benzes the compressor is always running. also if it doesnt take a charge from the low side you can try to charge it from the high side and that wil sometimes work.
AC
Are you sure you have a good vacuum ?
If you have air in the system you will not be able to fill it up and you will run higher pressures.
________
Vaporizer Volcano
________
Vaporizer Volcano
C220Freak
12-26-2009 10:38 PM
