IS ANYONE KNOWS IF I CAN PUT 22s on S430
Can i put 22s on my 01 s430.I been looking online and what i found that 20s will fit good,but you can still put 22s... I mean they will fit,but maybe when you are going to turn right and left they can touch that plastic... The reason why i wanne know for sure,because my friend selleng his 22s with tires really cheap...
yes you can
my friend had 245/35/R22 in the back and 235/30/22 in front and had no issues on good roads. But the thing is he always had the raise button on, so that the suspension would be raised a bit
you may have to grind off the stud and a little bit of the nut on the upper control arm for it to fit. I've seen a couple cars in the shop with 22's on them that barely cleared onlybecause of this.
Yes you can put 22" on the car. We have 22x9 all the way around and also have it lowered. The only issue we run into is when we are at high speed and the vehicles begins to lower itself it was rubbing in the rear just barely so we had to trim the inside of the rear bumper where the tire contacts
Check these out
http://i47.photobucket.com/albums/f1...s/L1020355.jpg
http://i47.photobucket.com/albums/f1...s/L1020354.jpg
http://i47.photobucket.com/albums/f1...s/L1020339.jpg
Check these out
ORIGINAL: 503motoring
Check these out
Check these out
summerchaser
09-29-2008 07:21 PM
juhoid
09-24-2008 06:30 PM
gabriellaavet
04-26-2007 04:56 PM
