All Dashboard Lights are Out
Old Mar 31, 2009 | 11:34 AM
Sidmariner's Avatar
Default All Dashboard Lights are Out
Last evening all the dashboard lights on my 1987 420 SEL failed to illuminate when I turned the car on.
The fuses are all intact.
I'd appreciate some guidance; is there a relay I should replace?
Old Apr 25, 2009 | 01:39 AM
Bounmark's Avatar
Exclamation 87' 420 SEL same problem
No one has any guess as to why this has happened...same problem as Sidmariner?
Started my car last night and all dash lights where out.
Please help...
Old Apr 28, 2009 | 07:57 PM
saleen1276's Avatar
on back of the instrument cluster where the gauges are there is a rehostat which controls the dimming of the lights....it goes bad and the lights will not work...the part is about $120 and has to be soldered in..
Old May 1, 2009 | 12:22 AM
Sidmariner's Avatar
Problem solved.
I noticed this evening that there was the faintest bit of light behind the thermometer. I tried rolling the dimmer control and noticed it would get a little brighter. Thinking back to how some of my old radios would act up, I realized the rheostat pot was probably a little oxidized.
After vigorously rolling the dimmer back and forth for a few minutes I was able to restore full brightness to the dash and radio face. Someday, I will have to pull the instrument cluster out and clean up the pot with some contact cleaner.
ultrarevvin1
UltraRev
Jan 13, 2014 02:56 PM
ultrarevvin1
Jan 12, 2014 10:20 PM
ultrarevvin1
Jan 12, 2014 12:07 AM
ultrarevvin1
Jan 11, 2014 07:11 PM
