95 S500 keeps overheating help!!
I have a nice 95 S500 with 163,000 miles car still looks great but having overheating problems. changed mono valve, changed thermostat, check water pump ( good ) also flushed system. I was told it might be the head gaskets are bad car does not leak don't have water in the oil idles fine when you drive it heats up fast 5 - 7 miles then 120 C. If it is head gaskets how big of a job is it? Thanks, to all that can help
My advice is as soon as it gets hotter than 100 stop right away, the aluminium head will warp peremenetly if it overheats too much!
Try changing the radiator, its probably full of crap, change the viscous fan clutch. What coolant are you using, Mercedes are very fussy, put in genuine Mercedes coolant at 50/50 and the car may then sit at 80.
bahia1017
06-19-2007 04:52 PM
