'94 S500 Headlamp Switch
RE: '94 S500 Headlamp Switch
It is not that complicated. Tame a small screwdriver and push it into the slot on the bottom of the **** which will release it. Then remove the phillips screws holding the panel, then remove the large nut and the panel can be removed. You do have to remove the knee bolster and then it should be straight forward plug in.
