'94 S500 Headlamp Switch
Can anyone point me in the right direction for replacing the headlamp switch? Is this a complicated fix?
Any help would be greatly appreciated. Thank you in advance, Justin |
RE: '94 S500 Headlamp Switch
It is not that complicated. Tame a small screwdriver and push it into the slot on the bottom of the knob which will release it. Then remove the phillips screws holding the panel, then remove the large nut and the panel can be removed. You do have to remove the knee bolster and then it should be straight forward plug in.
Thank you. I will give it a shot.
