92 300SE climate control problem
Old Jun 24, 2005 | 12:37 AM
milicev's Avatar
Default 92 300SE climate control problem
Hi im having a problem with my climate control. During the winter my heat wouldnt pump out at all. i Changed the blower regulator and now it pumps out a little bit even though it is set on high. my locks also stopped working during the winter.
Old Jun 24, 2005 | 01:01 AM
sleepwalker's Avatar
Default RE: 92 300SE climate control problem
water valve
Old Jun 27, 2005 | 02:43 AM
milicev's Avatar
does anyone know where that valve is located and what it looks like. Thanks, Danny
Old Jun 27, 2005 | 04:13 AM
W140?
[IMG]local://upfiles/1/4CDC5858A9D24F3CA0DBCC4C480B4B29.jpg[/IMG]
Old Jun 30, 2005 | 09:48 PM
milicev's Avatar
Sometimes the blower motor doesnt work at all and sometimes it just turns on. Is this still the water valve or is it something else.
Old Jul 1, 2005 | 12:28 AM
the blower motor?... then it's another story.
check the regulator or seized motor first.
Old Jul 1, 2005 | 02:30 AM
milicev's Avatar
I changed the blower regulator first and also when i connect the blower to direct power constant + then it works fine its a problem when its hooked up normally sometimes it goes on and sometimes it doesnt blow at all could this be the blower motor??
Old Jul 1, 2005 | 05:22 AM
so the motor and the regulator is fine and you can eliminate those.
something is sending a bad signal to increase or decrease the blower speed.
the evaporator not icing up? the evaporator temperature sensor is sending the right signal?
Dobbes
Mar 14, 2012 01:31 AM
lizardjack
Jun 25, 2007 12:10 PM
hammerhead
Jan 24, 2007 08:46 PM
linselpr
Aug 30, 2005 02:37 PM
larryc123
Aug 25, 2005 01:58 PM
