The 21 Mercedes Benz S400 is changed into a 20 inch blade big cake wheel hub, which w
Old Mar 7, 2021 | 03:11 AM
xiamin's Avatar
Default The 21 Mercedes Benz S400 is changed into a 20 inch blade big cake wheel hub, which w
Many car owners want to upgrade their wheels after they pick up their cars. Because Mercedes Benz S-class is full of aura, the most suitable modification for its appearance is to increase aura to make it more atmospheric and stable. Of course, a small number of car owners will upgrade their S-class appearance with sporty words, such as AMG siege, Black Warrior and so on. Today I'd like to share with you a wheel, which was used on the Maybach s560 Equipped with 20 inch blade big cake wheel hub!
email:1263882118@qq.com
wechat:Auroraspacexxx
TLE:+86 15697555244
A set of brand new Mercedes blade serrated wheel hub, the original wheel data is 245 / 40 R20, the front and rear wheel data is 8.5 J x 20 et 38 9.5 J x 20 et 38
High gloss wheels will undergo a number of additional tests, such as high corrosive salt spray test or 28 day weather test. Only the wheels that pass all tests can be included in the Mercedes Benz original light alloy wheels. These light alloy wheels can only be used safely after extensive development and testing projects. Each wheel design must carry out a large number of durability tests in strict accordance with the Mercedes Benz standards higher than the regulatory requirements, including special test procedures simulating real road challenges and material tests in advanced X-ray equipment.
A set of hub needs to be equipped with four hub covers and a special hub cover removal tool for the hub! After loading the wheel hub of this style, there will be a visual sense of wheel suspension during driving!
The 21 Mercedes Benz S-class can also be equipped with this set of wheels, showing a more advanced sense! No matter how to look, there will be no visual aesthetic fatigue!
2021 Mercedes Benz S-class upgrade wheel loading effect!
2020 Mercedes Benz S-class upgrade wheel loading effect!
Mercedes Maybach S450 loading effect!
flainn
May 2, 2012 10:55 AM
nbrock_85
Jun 7, 2010 06:01 PM
RB 900
Mar 14, 2010 04:25 PM
trev0006
Jul 9, 2009 01:19 AM
D NUTS
Sep 29, 2007 07:01 PM
