2005 S430 rear sun shade stuck in 'up' position..
Old Dec 19, 2015 | 04:36 PM
rmorrow1970's Avatar
Default 2005 S430 rear sun shade stuck in 'up' position..
Ive checked every fuse in the car (im told it is among four different ones possibly)...it is also the Q relay i believe?? Fuses are good..not sure about the relay, (does it use one).....it is stuck in the up position....what else to check, and most importantly
can you lower the shade manually? If so, what is the procedure as it is under tension...
thank you
Rick
Old Dec 19, 2015 | 05:07 PM
Ok, i rechecked every fuse, none were bad...i hit the shade button, and it lowered! i retried to open it, it moved about an inch, and made some odd noises...i figure its the motor...i hit the button again, and it lowered..i now will pull the fuse (anyone know for sure which one it is??!!) and just leave it down... now interestingly, immediately after this, the 'Pre-Safe Unavailable' warning light appeared on the dash!! seems too odd that they are not connected somehow? How can i reset, or recalibrate this thing to remove this warning? All help is appreciated!
thank you
Rick
todesto
Jun 26, 2014 09:32 PM
stevec230k
Oct 7, 2013 11:32 AM
stevec230k
May 24, 2012 07:03 PM
sahib
Oct 1, 2010 05:56 PM
benz_300se
Oct 31, 2007 08:25 PM
