2000 s500 speedometer
Old Jun 6, 2007 | 01:38 PM
604benz's Avatar
Default 2000 s500 speedometer
Hello,
My speedometer stops working after 5 minutes of driving it stays on zero everything else in the cluster works is there a sensor or fuse i need to check, any suggestions appreciated thanks.
Old Jun 6, 2007 | 01:56 PM
ARMENDS500's Avatar
Default RE: 2000 s500 speedometer
bring it to the dealer, they should fix it for
free, they extended the warranty on the clusters.
Old Jun 6, 2007 | 03:41 PM
604benz's Avatar
Mercedes Benz USA said the cluster recall was only for clusters that lights went out, the only thing on mine that dont work is the speedo needle.
Old Jun 6, 2007 | 04:57 PM
ARMENDS500's Avatar
i dont remember it being specific to the lighst only,
could also be you vss or the gauge it self is bad.
i am not sure where the vss is located though.
Old Jun 6, 2007 | 10:25 PM
II Kings 9:20's Avatar
The recall is for the instrument cluster which would include the speedo. My extended warranty letter which I just read again from MB says nothing about lights, it's for the entire cluster. This extended warranty is no different than if the speedo stopped working after the first week of ownership when new. That's how I read the letter. Call MB USA again and speak to a different clerk.
Old Jun 7, 2007 | 01:29 AM
snanceki's Avatar
The recall was initiated due to a poor internal connection causing display segments not to illuminate.
Whether the recall can be interpretted to include a faulty speed gauge I cannot determine. I would guess not.
The cluster fault is only on recall in the USA (in my view due to your liability laws) since the problem occurs worldwide and is NOT on recall elsewhere!
In fact MB try to cover issues like this by stating they are USA specific!!
Does your Cruise continue to work?
Does your trip Computer (average speed) continue to work?
I predict (subject to the answer to the previous questions) that the speed sensor (common to many systems e.g.ABS, EPS, Cruise, Auto locking, Airmatic, PAS etc) is working (i.e. Cruise continues to work). The speed signal comes from sensors in all four wheels but only one of these (the FRH I think) is used for vehicle rather than wheel speed.
In which case it is likely the speedo cluster gauge that is defective (dependent upon whether the av speed is still working)
If the av speed is not working then it is likely a communication (digital) issue internal (or possibly external) to the cluster.
Helpful?
Stuart
Old Sep 22, 2020 | 02:47 PM
Michaelqc's Avatar
Originally Posted by 604benz
Hello,
please respond
gixxer
Dec 27, 2007 05:14 PM
1eppy1
Apr 28, 2004 11:26 AM
1eppy1
Apr 23, 2004 11:34 AM
rcgiddings
Jan 22, 2004 02:29 PM
rcgiddings
Dec 18, 2003 02:00 PM
