1996 S500 coupe Check engine light is on
Old May 11, 2005 | 10:02 PM
Gary77's Avatar
Default 1996 S500 coupe Check engine light is on
Hello everyone! Few days ago my check engine light came on,yesterday I hooked up the computer and it showed me two codes, first was P0120 which is Actuator Actual Value pot.meter, and the other was P0203-Injector Cylinder #3(y62y3). Now, I tried to disconnect the plug from the injector #3, the car started to shake like one cylinder is not working, then I put it back on,and the engine worked fine,and in general engine is running nice and steady even with these codes. Then I tried to erase the codes but they never went away,looks like the problem is constant. I have a question, What the problem might be? What is the connection between these two codes?
Thanks for your time!
Old May 11, 2005 | 10:36 PM
sleepwalker's Avatar
Default RE: 1996 S500 coupe Check engine light is on
no need to worry about the #3 injector now.
the throttle valve actuator must be faulty... it can be the wiring to it also.
check wiring and connectors for any dirt or poor contact and corrosion.
Old May 11, 2005 | 10:47 PM
Gary77's Avatar
Hello sleepwalker! The connectors were the first thing that I checked, it seems ok,How do I check the if the current travels to the throttle actuator?
Old May 11, 2005 | 11:12 PM
are you using HHT or Star Diagnosis?
see the actual value of refference potentiometer. both of them. one going up, the other in opposite direction.
was the value correct? or the other one no longer moves? there's delay?
Old May 11, 2005 | 11:17 PM
Gary77's Avatar
I used the Snap-on Scanner-scop,Never check the value,Will check it tomorrow
Old May 11, 2005 | 11:19 PM
can do also because it shows the actual value.
i think you got WIS and can see on the wiring diagram which line is worth checking.
good luck
Old May 11, 2005 | 11:38 PM
Gary77's Avatar
What is WIS stands for?
Old May 11, 2005 | 11:41 PM
Workshop Information System.
very important if you do your own repair. everything is in there.
Old May 11, 2005 | 11:53 PM
  #9
Gary77's Avatar
I heard a lot of times,that because the extreme heat under the hood the wires in the harness are getting cracked up and than the problems start. May be I should replace the harness in this case?
Old May 12, 2005 | 12:09 AM
  #10
just do further check first.
only when you are 100% satisfied with your findings that you start to decide the next step.
parts are too expensive to make such error in diagnosing.
nolen01
May 7, 2015 05:58 PM
mercedes96c280colo
Jun 2, 2008 06:30 PM
solarant
Dec 27, 2007 11:34 AM
