1995 S500 Hydraulic fluid
Old Dec 3, 2007 | 11:40 AM
Koji's Avatar
Default 1995 S500 Hydraulic fluid
My 1995 S500 had been leaking some fluid for a while. Under the hood i noticed the reservoir that is labeled "Hydraulic" is completely empty. what is this used for? power steering?
can i get "Hydraulic fluid" from any auto parts store?
thanks
Old Dec 3, 2007 | 01:44 PM
uberwgn's Avatar
Default RE: 1995 S500 Hydraulic fluid
Koji, there's usually a part number right on the label. Did you look? You won't find these fluids at XYZ Auto Parts. Don't mix/cross-contaminate fluids. They're typically quite specialized and $$$.
Depending upon model, that reservoir can service just the suspension or suspension + power steering.
Old Dec 3, 2007 | 02:00 PM
Koji's Avatar
thanks uberwgn,
you mean there is a part number labeled on the reservoir?
Old Dec 3, 2007 | 02:19 PM
uberwgn's Avatar
ORIGINAL: Koji
On our car the fluid part number is printed on a yellow label on the reservoir fill cap. Check to see if you have the same.
Old Dec 3, 2007 | 03:34 PM
Koji's Avatar
thanks.
this is a 12 year old car that my brother gave me to drive with very low miles, about 60,000, but lately with numerous problems,from Starter, Rear suspension,Distributor Cap. He doesn't want to get it fixed from the cost standpoint relative to the age of the car.
it is just sitting in my driveway now but i just want to get it barely running to take it to the Smog check.
mikeselleck
Nov 29, 2023 02:50 AM
4smith
Jun 4, 2014 01:20 PM
Koji
Dec 3, 2007 11:20 AM
Lugnut
Jan 14, 2007 12:31 AM
ramminjammin
Jun 27, 2005 07:49 PM
