1994 S420 wont stay running
Hi
My 1994 S420 is having a no starting condition that have stumped
The condition; when I first start the engine it fires right up (usually after sitting for few hours or overnight) it runs for say 30 or so minutes and quit and wont re-start
While cranking no start, fuse in andno power to the pump and no clicking from relay
While cranking no start, fuse in relay out leads 86, 87, hot
Key on fuse out relay out leads 30 87 hot
Key on fuse in, relay out, leads 85, 86, 87 hot
Outside temp 98 pump temp 72 cold, running for 10 min temp 84
I pulled two codes the check engine light is not on
#7 (ignition system faulty – bank 1)
#19 (Injector circuit open or circuit short or emission control system adaptation at limit - Bank 1)
thank you
thank you
wraith6988
Sep 13, 2008 05:47 PM
