1990 300SEL Starting Problems
Old Mar 10, 2011 | 08:04 AM
lilda8615's Avatar
Default 1990 300SEL Starting Problems
Please help!
The car has been starting with hesitation the past couple days usually including a few minutes of just trying to start it it'll finally start and idle funny for a minute or two then do fine and run fine and everything. Once it's been started it'll usually start fine if done so within a couple hours of a previous drive. This morning, however, after just sitting overnight the car will not start. It tries, but it just will not start at all.
I have no idea where to begin!
Old Mar 18, 2011 | 12:20 AM
BlackWolf's Avatar
idle control valve and or cold start valve is not working properly. My car had exact same symptoms found it to be that the idle control box was dead and not sending electrical impulses at all. I havent replaced it, and will very soon, but the only other thing it could be is the actual ECU not telling the Idle control box what to do and thus the car is always in default hot start mode, which can be a pain when it shoulkd be in cold start mode.
Old Apr 12, 2011 | 01:45 PM
MB4ME560SEL's Avatar
Start with the simple things first. Check to see if the fuel filter is restricted if so replace. The should be replaced every 30,000 miles
Old Apr 13, 2011 | 08:22 AM
lilda8615's Avatar
Default @ BlackWolf
Where can I find these things for purchase and how can I test the existing components to know whether they're bad or not?
phat300sel
Oct 22, 2009 11:50 AM
Nfsjunkie91
Feb 16, 2009 10:19 PM
RonnieB
Jul 23, 2008 01:28 AM
mite5225
Apr 28, 2008 10:26 AM
Corvette
Apr 26, 2005 01:37 PM
