1985 w126 central locks.
Old Jul 30, 2011 | 08:37 PM
aduhaime2003's Avatar
Default 1985 w126 central locks.
I am currently trying to diagnose my central locks. The problem I am having is that locking any controlling lock will cause all locks to unlock. I obviously have no leaks.
What I have so far.
I have run the pump on the bench and if I ground any of the 3 pins the pump pulls untill the vac switch makes. Then if I apply 12v to a pin the pump pushes until the press switch makes.
I also tested the wiring in the car and all is correct.
I checked the switches on the controlling locks and the seem to be working correctly.
I reinstalled the pump in the car and the locks all work with a jumper to test 1 pin at a time. When I install the 3 pin plug, when any controlling lock is pressed th pump occillates and then pushes the locks back.
I am tempted to pull the system and go solenoid at this point.
I am not sure if I am missing something since my diagrams ate for 86 model year.
Any help would be great.
Old Jul 31, 2011 | 02:46 PM
Has anyone ever seen this? Is it possible I have incorrect vac pump model? Is there something with lock actuator adjustment? Anything....
hunter4348
Jun 4, 2015 08:19 AM
82Benzo
Jul 14, 2010 01:28 PM
Josh Flynn
Mercedes A Class
Dec 16, 2008 05:31 PM
Josh Flynn
Dec 15, 2008 06:59 PM
mjamfunk
Sep 11, 2005 11:02 PM
