1985 500SEL Fuse Map
1985 MB 500SEL Fuse Map
Location Fuse Functions
a 16A red Window lift front right, rear left
b 16A red Window lift front left, rear right
c 16A red Auxiliary fan
d 25A blue Front seat adjustment seat height rear respect front (memory) seat back adjustment
01 8A white Parking/tail light right, warning buzzer, illumination: license plate, instrument , heater and ventilation controls, switches, electronic radio
02 8A white High bean right, high bean indicator
03 8A white Parking/tail light left
04 8A white High bean left
05 25A blue Front seat adjustment, seat height front resp, rear (memory) seat fore-aft
06 16A red Low bean right, fog light
07 16A red Windshield wiper and washer pump, optical horn relay window lift term. 86
08 8A white Low beam left
09 8A white Cigar lighter, glove compartment light, radio, heating system for washer jets (seat heating front, ortho. Back rest)
10 8A white Climate control system, water pump heating water valve, blower motor inside temperature sensor, aut. Transmission electricals, overload protection valve, back-up lamp, relay auxiliary fan term 86, outside temperature gauge
11 25A blue Blower motor, air cond. Compressor, switch-over valve idle stabilization
12 8A white Stop-turn signal lamp, instrument cluster, diagnostic, warning monitor term. 8, cruise control, tachometer
13 8A white Diagnostic, hazard warning system, clock, central locking system, control unit memory of seat adjustment system, electronic radio
14 25 blue Heated rear window, horn, safety belt handover arm, cigar light rear (seat heating rear)
15 8A white Trunk light, roof light front and rear, illuminated vanity mirror, safety belt handover arm, door lights, automatic antenna, warning monitor term. 5
16 16A red Adjustable, heated outside mirrors (sliding roof, adjustable seat rear)
I'm a new member with a 1985 500 SEL climate control problem. Blower motor runs if directly connected to power - hence the motor itself works. Motor will not come on from power from climate control system - I checked the blower switch side teeminals of that system and believe I obtained the various voltage outputs - but still blower motor does't start. I even grounded the cold engine lock switch wire but still no power to the motor. Fuses are fine. I am obviously missing some link in the circuit. Any help would be appreciated. Thank you.
/s/. Old school
/s/. Old school
fitch11
Apr 13, 2007 02:45 AM
